Catalytic converter
Control de lanzamiento
Discusión y preguntas relacionadas con el curso Control de Lanzamiento
1787 Vistas
Hi,
You mentioned that ignition retard should never be used if you have a catalytic converter in your exhaust. My question is, if the explosions happen in the exhaust manifold and the catalytic converter is located in the downpipe which is after the turbo. Will it still be damaged?
Thanks,
ET
Hello yes it will be damaged
Regards Ross
Thanks Ross!
