Installing thrust washers/bearings
Control de lanzamiento
Discusión y preguntas relacionadas con el curso Control de Lanzamiento
3850 Vistas
Hello, personally I am building an engine that has the two piece thrust washer on the main bearing journal for the crank. When installing these and moving the crank, I assume we have the mating surface of the bearing lubricated when moving the crank to install these thrust washers?
hello yes you will need to lubricate them just like any bearing
Regards Ross
