launch control on ecumasters
Control de lanzamiento
Discusión y preguntas relacionadas con el curso Control de Lanzamiento
4083 Vistas
Hello,
I have a 2jzge na-t wired to a ecumaster classic ecu and wanted to try using the launch control feature for some flames out the exhaust and was wondering what values to put in to make that possible?
You need to add fuel and retard ignition when launch control is activated.
Thanks for the reply, I have attached a screenshot of the launch control with the values filled in, could these work for pops and bangs and the occasional flame?
