Launch control on standalone ECU(Link Atom)
Control de lanzamiento
Discusión y preguntas relacionadas con el curso Control de Lanzamiento
2757 Vistas
Hello, I have heard that its possible to activate launch control on a standalone ECU even if it does not have Launch control feature. 1 on my friend have done it on his car with link atom in it. Can you please explain how is this possible and how its done?
Hello the link Atom does not have launch control you could do some sort of basic workaround using 4d tables but I would not recommend it
Regards Ross
You can use one of the GP RPM limit tables if you want speed based launch control or just 2 step.
