4g63 EVO 8 oil jet
Crear hilos
2087 Vistas
Hello, I would like to know if the oil squirter needs to stay in all the build configurations or can be removed when forged piston are using? also i would like to know if have to be installed with a copper washer, thanks
Would have thought having the oil jets would help you pull the heat from the pistons. Why would you want to remove them?
