91 EE8 CRX Project
Crear hilos
4333 Vistas
Posting my build, which is done until I can learn to tune. I paid $700 for the car two years ago with an ebay intake/header/exhaust, ran fine, no leaks or rust, just needed new axles to pass inspection.
B16a1 w/GT2871R
OBD-0 to OBD-1 conversion
P28 ECU w/Hondata S300
Bored over to 82mm
Darton Sleeves
Wiseco Forged Pistons @ 10:5:1CR
Eagle ESP forged rods
Cometic Head Gasket
ARP Head Studs
Supertech over-sized Black Nitrade Domed Valves
Supertech Springs
Supertech Retainers
Supertech Bronze Exhaust Valve Guides
Skunk2 Pro 1 Camshafts
Skunk2 Lost Motion Assembly
AEM Cam Gears
Gates Timing Belt
Orbit ACL High-Performance Oil Pump
Moroso Baffled Oil Pan
ACL Bearings Kit
Skunk2 VTEC Solenoid
NGK Iridium Spark Plugs
NGK Plug Wires
Injector Dynamics 1000cc
AEM Fuel Rail
AEM Fuel Pressure Regulator
Edelbrock Performer X Intake Manifold
ARP Extended Intake Manifold Studs
Cometic Intake Manifold Gasket
Omni-Power 68mm Throttle Body
Speed Factory 4 Bar MAP sensor
DIY-Tuning TPS
Precision Turbo 39mm External Wastegate
HKS SSQV IV BOV
Speed Factory Full Ram Turbo Manifold
Fabricated Down-Pipe
Megan Racing Cat-back Exhaust
Speed Factory custom FMIC
Skunk2 Alpha Half-Size Radiator
Mishimoto bay Hose Kit
Mishimoto 68* Thermostat
Competition Clutch Stage 4 Sprung 6 Puck w/F1 moly-steel Flywheel
AEM Digital Gauges w/GlowShift Pillar Pod
HKS Type-1 Turbo Timer
Spectre Air Filter
Walbro 255lph Fuel Pump
Saikou Michi Oil Catch Can
12" Slim Fan
Megan Racing 32-way Adjustable Shocks/Coils
Innovative Traction Bar w/Black Powder-Coated Radius Arms
Password JDM Rear Upper Sway Bar
Drag DR-21's, 7.5" wide, Silver
Nitto Neo-Gen 205/15/50's
Insane Shaft Axles
Braided Brake Lines
New OEM Rotors
OMP Racing Seats
B&M Short Shifter
Battery Relocation to Trunk
As you can see.. When I first picked her up, she wasn't being taken care of:
But then I bought her and started treating her right.. First build was a cheap ebay kit to 260whp because I wasn't able to keep her at the time..
I blew the motor and found out I could keep her all at the same time, so then I started taking the build a little more seriously..
That is some build! what kind of figures are you expecting once done?
Thanks Chris! I may be in the UK in a few days, any races or events going on this weekend? As for the car, I'm not expecting more than 400hp at the wheels. I intentionally went with a smaller compressor because of the road conditions and tracks they have here. Once I get back stateside I may convert it to AWD and install a larger snail with two maps for street and racing. I love to build but I can't stand the thought of not being able to drive it!
There's the British super bikes at Oulton Park and the British touring cars at Rockingham this weekend, next weekend there's the British drift championship feeder series Drift cup on at Driftland in Scotland, probably plenty more that's all I have to hand just now.
Have you thought about a traction control strategy instead of 4WD?
I'm always open to options. I'm comfortable with awd setups but don't have much experience with fwd with traction control. I'll definitely be exploring things as I progress in tuning :)
