Adturb's Evo IX, Link G4+, Plex,
Crear hilos
2707 Vistas
Thought some of you may be interested in seeing my Evo IX. It's had a fair amount of work done, the main points being:
Engine- Cosworth 2.2 stroker crank, rods and pistons. Cosworth big valve MIVEC head, Cosworth cams.
Evo 8 FQ-400 exhaust manifold and turbo
Full 3" exhaust- HKS Hi Power Silent, de-restricted.
Jenvey inlet manifold and throttle body.
Link G4+ PNP ECU, Innovate MXT-L wideband, Plex uSDM-100 display.
The last Dyno run was 500bhp/ 440lb/ft at the flywheel. The limiting factor seems to be the turbo which may well be changed this year for a stock frame unit.
I've been fortunate enough to recently acquire the new Plex uSDM-100 so here's a little video of it in action! https://youtu.be/yFYTe3OXmi8
That's one tidy Evo!
