Another 2J.. may bore some and excite others
Crear hilos
2519 Vistas
I am blueprinting this motor for a friend of mine. Unfortunately, I failed to start this thread in its early stages such as teardown, fault finding (bent crankshaft and much more) but I hope you guys will not hold it against me if I post some photos of the blueprinting process, all hand written and seemingly a tad messy, which nevertheless I have pursued with the highest accuracy possible to me.
Here a couple of random pictures. I am trying to find a place to upload videos, if any of you guys can point me to a good place that would be great.
WISECO piston assembly, ring gaps adjusted individually, notes on the packaging. Custom made piston insertion tool,
You tube is always good. Thanks for sharing. How did they manage to bend a crank?
