Difference between Motec and Haltech inlet manifold pressure scale
Crear hilos
1889 Vistas
Good day guys.
As the topic states, Motec scale for inlet manifold pressure starts at zero and goes up to the desired boost pressure. However haltech starts at -100 tru zero and up to positive readings. If motecs zero reading and haltechs -100 reading is equal (or is it), how does the kPa reading work out at the top end?
