Dual Purpose 135i N54
Crear hilos
3792 Vistas
Hi HPA members!
Figured I'd put up my current build thread now that I'm officially a member of the community. Here it goes:
Car is a 2010 135i Automatic, with N54 engine.
I've done almost all the needed maintenance since purchasing the car at 76k from the original owner. With the exception of the injectors and HPFP.
I'm currently waiting on the JRZ RS1 Coilovers to arrive (450/700 spring rates). When they do, I'll be installing the M3 front control arms, SPL rear upper camber arms, Rogue Engineering rear toe arms, and Condor rear subframe bushings. While doing all that I may install a Wavetrac helical LSD.
Just finished putting on the painted Seibon carbon hood and trunk.
Car is sitting on Apex ARC-8 wheels; 18x8.5 +45, 18x9.5 +58 with Indy 500 tires.
I'm currently working on troubleshooting an issue with the Flex Fuel components, and will be looking through this forum for some information to help guide my testing.
Engine Modifications and Maintenance:
Pure Stage 1 Turbo - ceramic coated, 2’’
VRSF DPs
VRSF 2’’ Inlets
BMS Dual Cone Intakes
CSF Radiator
PSP 600i FMIC
Berk Mid Pipes (custom flex pipes added)
ER Chargepipe + HKS BOV
Radium OCC w/drain valve
RB PCV upgrade @ 88k
N20 Sensor w/BMS Adapter
Fuel-It Stage 2 LPFP
Motiv Flex Fuel Full Kit
MHD Flash + Custom Wedge Tune
xHP Flashtool Stage 2 Transmission Tune
BFI Engine Mounts
RE Trans Mounts
BMS Cabin Filter Delete Filters
BMS Oil Filter Cap
New Turbo Oil Lines
New Turbo Coolant Lines
New Turbo bolts
New Clamps
New O2 Sensors (top pair)
New Oil Pan Gasket + Bolts
New Power Steering Reservoir + Fluid
New BMW Coolant
New Uprated Vacuum Lines
New BMW Valve Cover + Gasket + Bolts
New NGK 9557 Spark Plugs
New Eldor Coil Packs
New BMW Oil Filter Housing Gasket
New BMW Transmission Pan + Gasket + Bolts (LiquiMoly fluid LL-01 certified)
New Drive Belts + Tensioner
New Upper Radiator Hose
ECS Water Pump Hose
Replaced OEM Water Pump
Walnut Blasted Intake Valves
New Intake Manifold Gasket
Flex Fuel Sensor, on Flickr
Turbo Install on Flickr
Seibon Carbon Trunk on Flickr
Pure Turbo on Flickr
Pure Turbo wheel on Flickr
FMIC on Flickr
FMIC+ChargePipe + BOV on Flickr
Valve Cover DIY on Flickr
Downpipes + Engine Mounts on Flickr
Painted CF Trunk on Flickr
Nice modlist.
Any more pics on progress ?
Updated with some pictures!
Cheers!
nice to see more n54 here in hpa !
Recently put on M3 front control arms, Rogue Engineering rear toe arms, SPL rear upper camber arms, ground control end links.
But major improvements being made this week!!
Getting the following bits installed at a local BMW shop as we speak:
- JRZ RS1 Struts (with upgraded clevis rear mount)
- Swift Springs ; 450F / 700R (Not pictured, Hyperco's not being used)
- Ground Control Race Camber Plates
- Whiteline rear upper shock mounts
- Wavetrac Differential
- Stoptech Stainless Steel front and rear brake lines
- Burger Motorsport Transmission Cooler (automatic ZF6HP trans)
- Condor Speedshop Rear Subframe Bushings
- Corner balance + alignment
BMW 135 Drivetrain Suspension install by Z U, on Flickr
agreed, awesome to see more N54 cars.
nice build as well.
Nice work!
Great to see some BMW builds on here.
I just picked up a haul of parts for my E90 320i - it will be a slow migration to the track as it approaches road-retirement. Probably not that interesting for anyone here at the moment, but may be worth starting a little build thread to keep track of things over time.
Looking forward to the updates on your build.
Cheers
