K20A Powered Lotus
Crear hilos
2268 Vistas
Hi all,
This is my 2003 Lotus. It's a elise under the skin, an early 'rover' car but re-bodied with a later exige set of clams.
The fun bit though is a K20A2 (UKDM 2004 Civic Type R) engine, with a jackson blower and chargercooler, JDM cams, custom 4-1 exhaust, honda box with Kaaz LSD, all fired by a Hondata ECU and under the eye of a RaceTech Dash2Pro. Rocking 330hp @hubs, to push along 808KG with 2/3 tank.
Tim
Congrats man nice car, should be very fun to drive... How much boost are you running? those engine fly with only 10psi!
Thanks! It runs about 9psi to make 330hp@hubs
I'd like to put a more modern and larger blower on it, drop the CR a point and see what it can make.
