my ongoing saga of an '05 honda type r
Crear hilos
2161 Vistas
Added more bits - changed the format - sorry for people thinking this might be a new project - its a bump
Spec
2005 - JDM Honda EP3 Type-R - Trim package is premiere edition with "C" options
6 speed C/R gearbox
Helical LSD
Recaro seats
Auto aircon
EXTERIOR
Legal window tints and a strip across the top of the windscreen
Headlight polish and UV protection
De-Badged
De-Stickered
INTERIOR
Shifter box solid mounted to frame
Pillow ball shifter bearings instead of rubber ones
MakoMotorsports dashboard cluster replacement to mount Haltech IC7 dashboard OEM style
ELECTRICAL/ELECTRONICS
New Battery
Engine grounding kit (5 point)
Haltech Elite 2500 ecu
Haltech EP3/DC5 plug n play wiring loom adapter kit
Haltech CANbus single Wideband O2 kit
Haltech CANbus IC7 digital dashboard
Haltech CANbus keypad – 5x3 layout
Haltech CANbus hub – 4 port
Haltech Tyre Pressure Monitoring System with internal sensors
UNDERCAR (Suspension/Steering/Brakes/Braces)
215x45x17 Bridgestone RE003 tyres
Updated steering rack slider bushing using Delron material
Hardrace full front and rear bushing kit (rubber)
Tein Endura Pro OEM replacement shocks (single adjustable)
ST Suspension OEM replacement springs
Project MU race brake pads 999 series
Project Mu 350 deg brake fluid
Strut tower to Brake master cylinder brace to prevent firewall flex
ENGINE/GEARBOX
Exhaust De-cat
1000cc Xspurt injectors - dynamically flow matched to within 1% of each other by MSEL NZ
Acuity hall effect TPS sensor
Haltech air intake temp sensor
Tegiwa carbon cold air snorkel intake
Gold foil heat insulation for the intake and intake metal heat-shield
Hasport billet engine mount kit (70a option)
Skunk 2 drop in baffle kit for the sump
Gearbox detent spring kit and internal gearbox centering spring kit
FUEL/IGNITION
Deatschwerks return style fuel system (fuel pump module, filter, regulator, lines, fittings)
NGK Ruthenium Spark Plug - HX 94279 (FR6AHX-S)
STILL TO BE DONE
Rear adjustable camber arms to correct camber after springs were installed
Roll center correction kit correct roll center after springs were installed
THINGS TRIED AND REMOVED DUE TO ISSUES
K-Mac camber and castor top hats for OEM shocks and springs
- workshop that has fitted these top hats previously on other cars advised that there were issues with fitment and design making it unsafe
K-Tuned oil pressure sensor adapter to allow extra ports (sensors / oil feed)
- leaked and was way too heavy for its size and the port it was fitted to and could have damaged the block if it pulled out
Auction site oil filter adapter plate to allow extra ports (sensors / oil feed)
- leaked between plate and filter
- also had a filter blow out the seal between the filter and block and dump 5L of oil due to a design fault with the plate
Car Stereo
- wanted to use the double din spot for keypads and the subwoofer was too heavy
Skunk-2 composite fuel rail
- was reading about failures with fuel rail fittings - nothanks
Great project keep up the great work
Regards Ross
Any updates and more pictures of you car?
