NEED HELP
Crear hilos
612 Vistas
NEED HELP WITH 4L60E TUNING – LS SWAP
**Vehicle Info**
- 1964 Impala SS
- 5.3L LS (Gen 3, 2004)
- Sloppy Stage 2 cam
- MAF deleted (Speed Density)
- 36lbs injector
- retro throttle body (for air only)
- Holley single plane mid-rise intake
**Transmission Info**
- Summit 4L60E (SUM-700461)
- 2600–2800 stall converter
- Gear: 3.08
- Tire height: 175/75r14
**ECM/TCM**
- P01 PCM
- OS: 12208322
- Running full SD (MAF fail/high freq disabled)
**My Goal**
To make this car drive like a factory new car nice and smooth but with a kick if i need it
- Smooth normal driving
- Correct shift timing
- Strong WOT shifts
- Clean TCC behavior
- No flares/slips/harsh shifts
**Transmission Issues I'm Seeing**
WHEN COMING T A STOP IT HAS A BUMP OR JERY FEELING IT FAITH AND WHEN IM DRIVING AND LETTING OFF THE GAS ALMOST FEELING LIKE I HAVE A STICK SHIFT CAR, IT LIKE ITS BUCKING. DURING MY VE TUNE I HAD NO ISSUE AFTER A DAY OR TWO I NOTICE IT SO BEGAN TO MESS WITH THE THROTTLE FOLLOWER AND CRACKER TO SEE IF THAT WAS IT BUT LIKE I SAID IT FAITH NOW AT THE STOP BUT IT THE DRIVE I WANT FIXES IF NOT ALL OF IT I FEEL LIKE AM CHASING MY TAIL IM NOT GOOD AT THE TRANSMISSION TUNE YET BECAUSE I HAVNT DONE ONE YET. BEEN TRYING TO FIGURE IT OUT BUT I NEED HELP ASLO TIRED TO FIX THE MPH AND COULD NOT COME CLOSE VCM SHOWS ME AT 45MPH AND SCHOOL ZONE SHOWS ME AT 37 MPH I DID THE TIRE WIZARD BUT NO LUCK I DONT KNOW HOW TO FINE TUNE IT
**What I Have Already Done**
- VE tuning in progress
- Idle airflow dialed in
- Fuel trims corrected
- Spark tables smoothed
- MAF tuning disabled (SD only)
**Files I Will Attach**
- My current tune (.HPT)
- A log of normal driving
- A log of WOT to show shift behavior
- A log showing TCC lock/unlock behavior
**What I Need Help With**
I need an experienced trans tuner to:
- Look at my shift timing tables
- Look at my shift pressures
- Look at TCC apply/release tables
- Recommend improvements for:
• Better part-throttle drivability
• Clean, consistent WOT shifts
• Proper TCC lockup with my stall
• Reducing flare/soft shifts
• Setting correct shift mph for 3.08 gear
Any help, suggestions, or revised tables would be greatly appreciated.
Thank you!
  • MARIO-1964-IMPALA-FINAL-TUNE.hpt
  • TCC.hpl
