sr20det power limit
Crear hilos
1802 Vistas
Im a building an silvia s15 right now, the engine as been rebuilt and im a bit confused over how much power i should go for and thought that maybe you could give me an idea?
The engine: SR20DET Black Top
Engine specs:
Tomei PROCAM in 260-12.00mm and ex 260-12.00mm
Tomei solid pivot lifters
Supertech headgasket
Supertech dual valvesprings and retrainers kit
JE pistons 10.0:1 (86.5mm)
Manley H-Beam rods (arp 2000 bolts)
Mazworks weider and more hole for lubrication ACL Calico coated race bearing main/rod
Mazworkz Headstudkit
Mazworkz Mainstudkit
Motul Oil, E85, oil coolers, etc etc.
What do you think?
Thanks! :)
to be fair talk to the engine builder and tuner,
you have left off a few varibles that would be hopeful like turbo
intake exhaust wat is it being used for etc
Well, the tuners arent reliable here. I was just curious about how the internals of this sr20 will hold up on the street. I fully understand that i need to match all surrounding parts.
With E85, that looks like a good foundation.
