M50B25 Turbo - Knock Sensors and VVT ?’s - MS3 Pro Setup
Curso de montaje de ruedas y neumáticos
Discusión y preguntas relacionadas con el curso Curso de Montaje de Ruedas y Neumáticos
1227 Vistas
On my E30 with MS3 Pro and a turbo m50b25tu (8.5:1 forged bottom end, 84.5mm bore and 75mm stroke, running 17-20psi on a g30-770 0.82ar at 82KPA elevation on 91oct).
First, I was wondering how I should set up the VVT (vanos)? Single vanos on intake cam putting out about 10-12.5 degrees when ON I believe (on/off only). On tunerstudio I can place the on/off duty based off KPA/load % and rpm. Would I keep it off when going into higher boost? Only use for low end torque and spool aid? Off at idle/decel? Then adjust VE’s accordingly.
Second, in regards to my knock setup, the base map came with it turned off - on the stock Bosch sensors (2) (m50b25tu), it looks like I can have them come in on the stock wiring to the PNP setup and Ms3 Pro Ecu - with the input type at “internal” to reference knock 1 & knock 2 inputs. Is there a way I can find a good baseline for the knock input threshold, knock gain, knock window start/duration, and coolant scaling? I currently have the band-pass frequency at 6.94 kHz and integrator time constant at 75. I have cylinders 1,2,3 referencing sensor 1, then cylinders 4,5,6 referencing sensor 2.
Additional tuning parameters -
a. Recommended MAT ignition retard? Stick with standard ideal gas law MAT correction curve values? *open element IAT sensor mounted in intercooler piping before throttle body/intake.
b. Use a AFR safety once tuned. Ex. 0.3 afr lean discrepancy for 0.3s or more over 130kpa to cut spark? Recommendations?
c. PWM idle control valve voltage corrections? Standard voltage I have seen with running car is around 14-14.3v. How to determine +/- % corrections for higher/lower voltages. *Stock Bosch 3-wire.
Thanks
  • Los archivos adjuntos solo pueden ser descargados por miembros Gold de pago. Lea más sobre cómo hacerse miembro Gold aquí.
Normalmente respondemos en un plazo de 12 horas (a menudo antes).
¿Tienes problemas con el sitio web?
¿O necesita contactarnos por algún otro motivo?
