Stiffness of a steel Wheel
Curso de montaje de ruedas y neumáticos
Módulo relevante: Factores de rendimiento > Rigidez
Discusión y preguntas relacionadas con el curso Curso de Montaje de Ruedas y Neumáticos
1578 Vistas
how does the stiffness of a steel wheel compared to that of and aluminum wheel.
depends on everything - most notably design, and material thickness. Normally we trust that the design of wheels you purchase is adequate for the task. So normally, people worry about the size and weight. Lighter weight wheels/tires can have superior performance (traction) over bumpy surfaces.
