AEM DASH CD7 TO MOTEC M800
Discusión fuera de tema
1940 Vistas
Hi All,
I need setup for Motec software & AEM dash .dbc file for can signal setup
Hi,
You will need to contact AEM for information on setting up the CD7 to receive the CAN data from the M800. Unless AEM are requiring a Custom CAN Data Set, you will be transmitting one of the standard datasets out of the M800. The M800 does not accept a dbc file.
