Aem Series 1 Base Map for Rx7 Mazda rx7 Fd. Help.
Discusión fuera de tema
3503 Vistas
Does someone have for series 1 AEM a base map for stock rx7 fd. I ll appreciate your effort and help. Thanks in advance guys.
This is a very old map, but it should be a little better than the original 30-1800 base map. The map uses stock injectors (550cc/850cc) and the stock MAP sensor for the main fuel map load. The car wiring was changed so the ECU's injector#9 output connected to the prespool valve for sequential twin turbo control.
Be very careful, rotary engines are fragile.
  • 2008-07-25-SB-RX7-stock-550-850cc-injectors.V1.19.cal
