Air temp sensor placment
Discusión fuera de tema
2024 Vistas
On a twin turbo set up with two pipes coming up to the throttle body, were is the best place to place the intake temp senor coming off the intercooler, Pre nitrous nozzle? or after? I am going to use dry system to keep it more simple as far as pluming and cleaner on the intake, I do know that direct port nitrous is the best way to go as far as making sure the same amount goes into each cylinder.
If it merges into a single throttle then just after the merge but before the nitrous nozzle
