AirLift Digital Controller USB Data Cable Shielding Question?
Discusión fuera de tema
1148 Vistas
I am rewiring my AirLift 3P/3H Harness, due to the bulk of it and noticed that the AirLift Digital controller harness is shielded yet, they terminated the shield directly into the ground junction, which is pretty much tied into the main grounding point(s) at the relays, etc...
Do you think this is the appropriate way? Or should I terminate the shielded ground into the 18-way connector at the main module?
Thanks in advance!
How much resistance do you measure between the 18-way connector ground and the 'main grounding point'? If it's small (
