automatic transmission - Stand alone/Wire inn
Discusión fuera de tema
1760 Vistas
Hi!
I own a Nissan Stagea c34 Rs4 with a rb25det s2 automatic transmission, and have for a longer time tried to find a ECU i can use insted of the stock one.
The only info i can find, is that unless i got a Neo with a Auto and can use nisstune, ther is nothing within my price range, someone told me about something called "Wolfe Ecu", but the kit i needed was way to expensive.
All i need is something that can control the engine and Gearbox due to a lot of gremlins in the car, not looking to gain power.
