Body shop in Auckland for body rust repair/modifications?
Discusión fuera de tema
2891 Vistas
I have need of a decent, reasonably priced vehicle fabrication/rust repair shop in the Auckland area, if anyone can make suggestions to check out?
Initially replacing front panel/valance, repairing rust in and modifying radiator support to remove bonnet catch (will be using bonnet pins) and an area around the base of the front windscreen. If the work and cost is acceptable, there may be further work to be done.
No one got a suggestion, a fab'/repair business that does good, sound work without 'taking the piss' in charging?
I did have one in mind, but he's since retired, and with parts coming from the UK I'd like to get things set in motion this end.
I finally remembered to ask my sister "who did the work on her gt6 for her" when she restored it - and got back that a place in Auckland called "PK panel and paint" who have recently moved from grey lynn to henderson. They work on euro cars (they have lambos etc in there as well) or custom projects etc - I was very happy to see the before and after results - as was she. The AA magazine even featured her car when it was done as the results were so nice. The GT6 is a wonderful shaped car :)
Its probably an expensive place as my sister "like money and nice things" but they were able to do the restore on the panel and paint and convertible roof sort the and engine / gearbox conversion etc.
See what you can find out about them yourself if you like - they don't seem to show up on google easily tho
