Building a 7afte engine with Greddy Emanage
Discusión fuera de tema
2680 Vistas
Hi Guys
I have already built the motor and I have thrown it in a Trueno AE85
Got my self a second hand Greddy Emange blue but the manual is in japanese..
I need help on setting this up. A wiring diagram would be a great help.
Thank You
Hey man,
Could you give the spec of your engine, the e-manage blue is a pretty restrictive tool for your application: for example, you have to use almost stock config of your hardware, you can't decrease fuel injector's duty, etc.
Also, I'll recommend you to find how to "upgrade" your unit up to the "gold" version, it helps you log a a/f signal from the external wideband.
  • e-Manage-blue-Installation-GReddy.pdf
the engine is 7AFE with stock displacement and I have lowered the compression by using a thick gasket. The intake and exhaust is custom built as u can see and the turbo is a TD04. I'm planing to run 0.5 bar boost untill I do a proper internal mod to this motor.
