Difference between inline 6 cylinder engine and V lined
Discusión fuera de tema
2385 Vistas
Hello everyone,
I want to know the difference in the setting for example if i am tuning a m800 whats the difference in the setting of a inline and V lined engines?
Thanks
There's no real difference as far as the ECU setup is concerned. With the M800 you need to wire the injectors and coils in firing order but this is the same regardless what engine configuration you're running. The other aspect that's critical is the Ref/Sync mode but again this just needs to be selected based on your engine and the trigger system.
Is there something specific that you wanted information on?
