Dyno -46. programme
Discusión fuera de tema
1518 Vistas
I have an inertia motorbike dyno , with a Dyno-46 software programme , and am unable to get that to function properly
does anyone else have this system ? ( its a Malaysian programme from 2006/7 , and appears to have only been around for a short time )
I have 2 pc s one with Windows XP , the other with 8.1 . upgrading to a new software system is a likely scenario, but getting this to work would be good
hello from memory there was a lot of issues with this software i remember trying to use one years ago
best of luck
thanks for your reply
http://www.dtec.net.au/index.htm , https://yourdyno.com/
i am looking at these 2 systems
Dtec is an Australian system ,and YourDyno is from the US , any comments or advice would be. appreciated
i have 2 discs fitted to the 200 kg inertia rolller , that i can apply load to ( its crude but effective) and i may be able to incorporate a load sensor system ( making the YourDyno possibly a better choice )
thoughts ,? comments ? , experience s ?
