ECU Master ADU - virtual fuel tank - Link 4G+
Discusión fuera de tema
2342 Vistas
Hi Guys,
I use a Vipec ECU with ECU Master ADU5 and want to activate the virtual fuel tank. The ADU5 needs a "fuel used channel" to work.
The Vipec only transmits "instantaneous fuel consumption". So I need to add up the values to get the correct fuel used value.
Anybody an idea how I can do that?
this is really only a feature in the link x series links I'm not sure it can even be done in the vipec at all
