electronic power steering pump control
Discusión fuera de tema
1515 Vistas
i want to use electronic power steering pump in my build i have motec m150 ecu which pump i can use and can control with my ecu ,most of the pump need specific can bus signal?
I don't know what firmware package you are using, but I don't believe any of the GP packages have any special support for electric power steering systems.
