Glossary of terms
Discusión fuera de tema
1660 Vistas
Just a suggestion. Can you create and display a section called Glossary of Terms?
For instance MAP MBT etc.... Post the term and definition of what it refers too. This way if watching a video and we are missing a definition we can easily visit the glossary and get the meaning.
I realize this is a online way of learning but sometimes printed materials will help.
A booklet that we can download would be helpful.
Thank you in advance for your consideration.
With so many being used, sometimes similar acronyms for different applications, it isn't a bad idea.
If you enter "guide to automotive acronyms" into your prefered search engine, you will get plenty of hits. For example - https://www.aa.co.nz/cars/automotive-acronyms-what-they-mean/ or this which has over 3000 acronyms - https://www.smmt.co.uk/automotive-acronyms/
Some can be even be downloaded as PDF files to be printed out.
Thank you for your response and I did visit these sites. I was hoping more for the terms that Andre refers to. It would not be that hard for HPA to write down each term with a meaning and we can print it out. Maybe 20 or so.
Has anyone from HPA seen my request and will you consider creating a glossary as suggested?
