GTR 32 Tps Out Signal
Discusión fuera de tema
1445 Vistas
what type of signal out from ecu to 4wd
analog voltage or pwm
Pretty sure OEM is a 0-5V Analog.
But you can use a PWM 2D table to "replicate" that signal with aftermarket ECUs
