Link G4 and Racepak
Discusión fuera de tema
2627 Vistas
Is there any chance that someone may be kind and generous enough to help me with some guidance on how to get some data to display on a racepak IQ3 non logger from a post 10000 ser no G4/V88 (actually v88 but i was told they are the same as G4). To be honest i dont really understand the settings on either software and i find the Racepak datalink especially confusing. I have a module from Racepak that says for G4+ and i have been told that this is correct, i also have a Vipec module but had no success with that either. I must have wasted days on this so far and i'm nearly ready to throw the Racepak away.
Thanks in advance
Hi Leon,
The Vipec module uses serial and the G4+ module uses CAN, either one should work (CAN is the better choice) but they need setting up in different areas in the software.
You can email adam@linkecu.com and I should be able to work through it with you or we can arrange a time I can jump on teamviewer and give you a hand.
