LOGGING PROBLEM
Discusión fuera de tema
1531 Vistas
good day every one. can some body give me some advice on this issue. i 2002 subaru wrx sti is not logging properly. its shorting out for lack of a better term. when ever am logging it seem like all the sensors are dropping out from time to time. might be a ground or power problem. i will attached a copy of the log so u can see where is bugging out. i am using ecuedit
  • LOGGING-ERROR.csv
I don't see all the sensors dropping out. I see some channels (mostly calculated channels in the ECU) that aren't updated very frequenty. Channels with sensors attached (Throttle Position, MAP, MAF, IAT, ECT) seem stable.
What software are you using for logging? What is the units of the time column? milliseconds?
I'm not sure what is the time unit. I am using ecu edit. Also the knock sensor is showing error reading. That is the one that caught my attention. Am thinking its power or ground on the same circuit with the knock sensor or the obd2 port
