Low Pressure/High volume lift pump
Discusión fuera de tema
2247 Vistas
Hi Guys,
Just after a bit of info on what your using as a lift pump up to a surge tank?
Cheers
G'day Daniel. It depends on your situation, I've used the stock in tank pump and cradle setup in cars before without too many issues, but I did wonder if they'd end up failing because they're constantly running un-loaded, but no problems so far.
Facet and similar low pressure carby pumps are pretty common too, but they're awfully noisy.
