ls1 VATS (vehicle anti theft system)
Discusión fuera de tema
2126 Vistas
Hey guys, i have a question as how to remove the VATS from a ls1 ECU. is there a program i can down load that will allow me to remove the VATS? Thanks in advance.
You can use HP Tuners or EFI Live to remove VATS from the ECU. I'm not aware of any cheaper options sorry.
Thanks andre, I'll look into it :)
