Mainline dyno wideband
Discusión fuera de tema
924 Vistas
Hi all,
My Dyno's wideband (Tech Edge 2DP) recently died, and I'm currently looking for a replacement. The Dyno I use is a Mainline Dyno.
Would it be possible to use the AEM X Series wideband as a replacement? Any compatibility issues or considerations I should be aware of?
Thanks in advance for your help
It seems to use a LSU 4.2 or 4.9 - https://wbo2.com/2d1/2dp.htm
The AEM seems to use a propriatory sensor or a 4.9.
So, it may be possible to use the latter, if you know exactly which you have, but I STRONGLY advise further checking!
