Manifold surface temp sensor
Discusión fuera de tema
1589 Vistas
Looking for an NTC sensor to measure intake manifold surface temp. 6mm ring type would be ideal. What's out there?
Something like this:
http://www.carrel-electrade.co.nz/sensor/pdf/pt105-rt.pdf
Thanks David. I wasn't sure that I could use a PT100 type having a resistance that low. I was thinking something more in the 5k or 10k range. MoTeC M800.
You should have mentioned any limitations. You can use this on an AV input with a proper pull-up resistor. You could also look for PT1000 sensors.
I know you said NTC, and PTxxx are positive, but I think you really meant resistive-type sensors.
