Motec m800 dbw
Discusión fuera de tema
1683 Vistas
Hey guys I got a land cruiser with a motec m800 it was running a dbw it was working fine but I need to remove the map and down grade version 3.4 so now I don't know yo set up the dbw system I know all the inputs and outputs but don't know how to set it up and it has the option for dbw.
V3.4 has been removed from use by MoTeC for a very specific reason, you should not use it in a vehicle. MoTeC Will not provide support for any Mx00 running V3.4 Firmware, and will upgrade it to V3.54.
