Quarantine projects
Discusión fuera de tema
1414 Vistas
In Australia and much of the world at the moment a forced quarantine in light of COVID-19, now lets not dwell on this or the severity.
instead lets all show what we are working on, all those little projects that we never finished before or didn't have time to finish previous.
ill kick off with these steering rack limiting spacers i am getting 3D printed. test pieces have worked just changed some tolerances.
once these work i will start on some front brake ducting but these are required to give me chassis to wheel space for the ducting.
these limit steering lock and give me about 30 mm clearance. the simply clip on to the steering rack and away you go.
