Shops that sells 1FZFE Complete assembled engines in Dubai or Australia?
Discusión fuera de tema
1295 Vistas
Hello guys im looking to buy a complete assembled engine build for turbo . What shops yall recommend?
No recommendations, as such, but I would suggest, when narrowing down your builder/supplier, you have a good idea of what level of boost, rpm range, budget, etc, and exactly what additions to a "long" block you're going to need. As with any other build, depending on what you need from it, it could be a close to OEM parts selection, through off-the-shelf aftermarket, to custom aftermarket.
If you search this channel, they have at least a couple of builds, a mild and a wild one, and might give you some ideas, and might be worth giving them a call - https://www.youtube.com/@BoostGumps/videos
