Speed sensor options
Discusión fuera de tema
1711 Vistas
Hi,
I’m thinking of 1.5 jz + bmw dct conversion in Soarer . The car never had abs , what are the options to get the speed reading?
I can't recall what ECU you're using, but some will interface with a GPS receiver to give speed and distance covered.
If your legislation required a physical measuring method, some have used sensors to pick up signals from propellor shaft flange bolts, disk retaining bolts or if you pick up a ring and sender from an ABS equiped vehicle, you could use that as a signal. Any of those can be used as a speed signal for the ECU, if supported. Heck, infra-red and RADAR pickups that measure ground-speed have even been used, but that's a bit beyond me.
Those are, of course, if the gearbox can't be fitted with a speedo' gear signal generator.
Will be running Ecumaster EMU BLACK
