SR 350Z Mounts
Discusión fuera de tema
1622 Vistas
Hey,
I asked the question in the DMs, but was told to ask it here in an effort to reach a larger audience who is interested in this swap. I am planning on swapping the SR20DET I have sitting in my S14 right now into my 350Z and was wondering if you guys are willing to share some photos of the mounts used for the SR swap into the 350Z. What transmission were you planning on using before swapping the SR into the 86? How far forward was the SR mounted? I have the same moroso pan, but I may end up going dry sump in order to get the motor as far back and low as possible. I also have the Ross dry sump pan, just trying to weigh all my options before I actually make up my mind on direction.
Last question, I know this isn't the "proper" location for this, but I don't want to create multiple threads. It was stated you are willing to share the documentation of the wiring for the SR 86 swap and am wondering if you are able to post it here or where it will be posted.
Thank you for everything you guys do for the car community!
Kevin
have a look thu this and see if anyone can help you out
https://engineswapdepot.com/?p=20371
Regards Ross
