TDC OFFSET haltech elite
Discusión fuera de tema
1686 Vistas
Good day. Can some one help me here.
I locked my timing in the haltech at 10 degree and it showed 10 degree on the timing light. Does that mean that the TDC Offset should be set to 0⁰. I have started tuning the car and it's running fine BUT the TDC offset is set to 40⁰. Is this normal? Should I leave it there or set it to 0⁰?
