what ecu ? nissan ca18det
Discusión fuera de tema
3967 Vistas
hi guys any ideas on what may be needed to get a nissan ca18det running with a halltech elite 550
im looking for great tune ability yet simplicity,
unsure whether this ecu will be able to do electronic boost control , fan control , just the basics
the main concern i have is in what else i will need to get the car on the street , this is really on a tight budget , any other ideas on ecu choice ? i have looked at , Nistune & maxx ecu
The specs of the Elite 550 are listed here: http://www.haltech.com/new-product-elite-550-is-here/
It includes 5 DPO's (digital pulsed outputs) so could handle cooling fan control and electronic boost control with no trouble.
Your cheapest option is likely to be the Nistune board. I've had limited experience with Nistune but it is a reasonable and well priced solution for mild builds.
Bang for Buck you cant beat Nistune. Can get one supplied/fitted/tuned for $700-1100.00 AUD
usually just the ecu will cost that much
