What`s the wire size and type used in...
Discusión fuera de tema
2636 Vistas
...the looms shipped with links, motecs, DTAs and so on? The ones with the superseal 1.0 connectors. As it turns out not everything fits into the small holes in the connectors so im wondering what wire gives the best fit yet yeld the biggest cross section concerning amperage draw and still is possible to install into said connectors.
I don't know what those brands use, but the contacts are made for wires between 20 and 16awg (0.5 to 1.25mm²)
The largest gauge the MoTeC uses in the cut to fit Mx00 looms is 3.1mm2 for the ground,
