Windscreen or dash mount for Plex V2 Knock Monitor
Discusión fuera de tema
2212 Vistas
Anyone have recommendations for a mount that will attach to the Plex V2 and suction to a windscreen?
I've actually recommended to plex that the put a threaded boss on the back so you can use a universal camera mount. I'm not too sure that will happen unfortunately.
My current technique is to use a gopro adaptor that attaches to the back via double sided tape. I've then got a windscreen mounted suction cup with a ball-mount that allows me to orient the Plex however I want so it's easily viewable.
Thanks guys, I have a couple different GPS mounts coming from Amazon to try out.
