wrap around text format on your forums
Discusión fuera de tema
2196 Vistas
Maybe its a browser setting of mine, but can you look into the formatting of "end of line"/"wraparound text"? If a word cannot complete by the end of the line, the word is cut off to be continued on the subsequent line. Sorry to nitpick but its distracting. This is probably a setting in your forum tool.
Another thing to fix is the time zone / time stamp for posts.
When im on the home page, the post 'age' (minutes/hours/days since post was made) is correct. But when i go into the sub-forum is diplayed 4 hrs advanced.
Hard to describe, but annoying.
The post times are relative to New Zealand local time I think. I get +20 hours on any new new post.
Yeah. But only from the sub-forum pages. When you are on the main page of the forum, the time is correct.
Test post at (I'm in NZ) - 4:32PM local - 3:32 am GMT
Just noticed, it has the time twice and it's GMT - you guys the same?
Doh, checked my profile - I still had it set to UTC - changed it to Pacific-Auckland and now correct. You may need to check the applicable zone for you carefully, as may not be in an expected format.
