hi i run a big single turbo fd3s rx7 in the uk as a street, drag,drift,track car, i wanna use it for everything that i can, im running it on a apexi power fc atm, i have dataloggit etc for it. i was hoping to run 2 step on it for drag racing, i know that you can get a power fc with this on but mine doesnt have it. i have looked into other ecu's so i can have this but alot of people say its really bad for rotarys, i know that it will produce heat etc but is it really that bad for a rotary over a piston engine? also do you have much to do with power fc's and will you be doing more vids on 13b's thanks curtis
