1995M Miata boosted MS2PNP Questions
159 Vistas
So I am about to start my first tune with a buddy and was wondering all the engine and sequential settings that I need to input. Specifically the sequential settings, i have seen some people say semi/sequential, sequential, or untimed injection. And also the barometric settings, i do not know if I should use initial MAP reading or 2 independent sensors. If anyone could share their settings for their miata would be very helpful!
Engine is stock internal and all wiring is untouched
Rx8 denso yellows, yes I know they don't have a good wrap but those are the ones we are working with currently till he gets different ones
MS2PNP Ecu
