2jz trigger set up
433 Vistas
Hi,
2jz gte on haltech S3, I’m trying to set up the trigger.
This one has the 36-2 gear (oem 12 teeth swapped with phr billet gear) on crank and 1 tooth home on cam G2. Still has reluctor sensors.
Trigger is not oem so it is set to generic missing teeth / 1 tooth home.
I can’t get the sensors to sync.
When cranking the engine, I don’t get errors but it tells me « syncing to pattern »
I did an oscilloscope (see attached).
Does anyone have experience with this set up ?
Thank you.
Could you attach your tune and a log, or post a link to a Dropbox?
You have a wiring fault.
The crank trigger pattern is clearly visible in the sync sensor trace.
It also looks like you might have the pull up enabled on the crank trigger signal?
The trigger input state should change for every zero crossing of the input signal, like you see with the home signal.
