2JZ VVTi home percent
197 Vistas
Hey all!
Like in my title, I have a vvti 2J i recently got up and running on a haltech. My question is, is a home percent around 7% acceptable for this trigger? I've gone through cam and crank wiring and verified mechanical timing, etc. Being a fixed pickup i know there's really not much i can do to adjust it. I did swap between rising/falling edge for curiosities sake but that netted the same results. I ask as the couple of other setup's I've done with this engine the home percent was much more 'reasonable', and i like to err on the side of caution.
I did find a post outside of this forum where a gentleman had a similar number and a commenter said that it was fine, but i wanted to get a second thought or confirmation!
Appreciate your time!
