ECUMaster USBtoCAN, compatible software?
552 Vistas
Hey all,
What other software is compatible with the ECUMaster USB to CAN device? Could I use PCANView or Busmaster, etc?
Thanks
Light Client and other Ecumaster device software is the only thing I've found that works with their USBtoCAN device. Tried many different softwares, savvyCAN, wireshark, peakcan etc
Depending on what you're doing light client can probably do it, just maybe not as efficiently as others.
Good to know, thanks!
